Pixelating Bt Sport recordings
- TV
- Pixelating Bt Sport recordings
16-01-2020 5:38 PM
Ithe issue has got worse as every internet recording I make pixelates badly and i have n idea what to do. The issue does not arise on live TV,only recordings.Aerial tv channels are fine as well
Re: Pixelating Bt Sport recordings
17-01-2020 6:06 PM
18-01-2020 6:34 PM
i am not sure what i can do tbh. I switched off at the mains and rebooted but that is all. It only seems to pixelate with recorded internet material.
19-01-2020 9:12 AM
i also disconnected and reconnected all the leads to no avail
20-01-2020 3:56 PM
Thanks @donmaico6
Could you try resetting the YouView box (as the instructions here) and let us know if that helps?
Best wishes
Dave
22-01-2020 4:54 PM - edited 22-01-2020 4:54 PM
I'll endevour to do that when i have a moment,thanks
23-01-2020 9:37 AM
i have succesfully done a factory resety whilst keeping my recordings.Will let you know if there is an improvemnet this coming weekedn when i shall make the next recordings
23-01-2020 7:49 PM
