No internet channels
worcsguy
Today I'm getting a BTV-420 error on all my internet channels?! Router and internet working fine for everything else...
14 REPLIES 14
SteveA
Re: No internet channels
Yes so am I...
Tried to get an online support chat but they aren't around.
I suspect its another mess up like the other week.
worcsguy
Guess it's not just me then! So if there's a problem on a Sunday then we live with it until normal working hours? Lol
SteveA
No I think they're snowed under...
Just phoned them and was told the wait time was over 15 minutes....
HairyMcbiker
Fixes: 21
All the BT help stuff says reboot both the box & the router, might be worth a try rather than wait till tomorrow.
SteveA
All ready done that....
BTV-420 isn't an error message recognised by Plusnet's trouble shooter...
SteveA
Finally got through to PN Support, talked to someone for 30 seconds and now I'm back in the queue.
SteveA
Another full power off all the PN kit in the house fixed it.
Fixes: 1,291
mine's been uninterrupted this afternoon, so doesn't seem PN wide.
SteveA
It sounds like BTV-420 is a pretty low level error.. its not something PN have been trained up on
I suspect it indicates a complete loss of multicast.
Mayfly
Seasoned Pro
I was getting that error on Friday but only on Eurosport - internet was OK, I rebooted and it settled down but then it started with problems again this afternoon.
I can't remember the message today but pressing the OK button twice seemed to reset it them 20 minutes later started all over again.
HairyMcbiker
Fixes: 21
Mine doing it today, was fine earlier but now got the 420 message.
Chris
Legend
Fixes: 169
From a bit of google (that error isn't one I've seen before) that is quite a generic error, so not much I can advise over rebooting the kit as a first step.
systemcorehome
We seem to be having exactly the same problem this evening (24/251015) - all bundled YouView channels coming back with error BTV-420 (though all other channels seem OK ) - tried rebooting the box, the router, rescanning channels,  updating software - nothing makes any difference. Typically, occurred at peak time, just when PlusNet support line no longer available (out of hours).
2 weeks ago we had slightly  different problem - all our YouView channels simply disappeared - needed to rebooot box & do complete re-scan to get them back again. Couldn't get through to PlusNet support even after hanging on the line for 20 mins which we were charged for!
Please sort out the problems PlusNet!
chrisfairclough
Kept getting ipc6007. After servers attempts and hours finally got through to the tv tech team.  Try turning the power off at the back of the box hold the down button the box and then switch the box on, as soon as you get a Maintence y/n press the power button on the box. Wait for the waking up screen for a couple of seconds and you get a maintence screen try the facotoey reset but keep recordings option then follow all the instructions on the tv. It worked for me good luck!!
