No Fibre modem
andyblac
No Fibre modem
plus net offered me PlusNet Tv to trial for free for 18 months, as i came from BT with a HomeHub5 router (build in modem), which got returned to bt when i switched. i have been using my own FritzBox 7440 router since. But as part of the trial PlusNet sent me a PlusNet Router with the YouView box, but it seems that the PlusNet Router needs a external modem. how do i go about getting one ?
Andy.
7 REPLIES 7
hooverman
Re: No Fibre modem
on an install by plusnet a seperate modem  supplied is a  BT openreach  Huawei hg 612    ,This router is normally supplied by BT ,so it might be worth contacting Plusnet to see of they can gat one supplied to you ,failing that you can buy them on ebay,etc  or if you can get hold of a Homehub 5  and convert it to be used on Plusnet  I currently use a Homehub 4 via a BT modem
      So before spending any money try Plusnet  first they should be able to get you one
w23
Fixes: 4
Re: No Fibre modem
Not much immediate help but this might be of interest: http://community.plus.net/forum/index.php/topic,140687.0.html
Call me 'w23'
andyblac
Re: No Fibre modem
anyone from PlusNet here ?, can you arrange to send me a Fibre modem (NOT the Router, as you have already sent that.)
thanks
Andy.
PeterBirt
Re: No Fibre modem
Sadly I am not at work today but if you contact us on live chat we should be able to arrange for a modem to be sent to you.
https://www.plus.net/home-broadband/contact/
MatthewWheeler
Fixes: 405
Re: No Fibre modem
I've ordered a modem for you now.
It should be with you in the next few days.
 Matthew Wheeler
andyblac
Re: No Fibre modem
arrived today, thank you very much, fanatic customer support.
andy.
MatthewWheeler
Fixes: 405
Re: No Fibre modem
Glad to hear you got it Cheesy
 Matthew Wheeler
