Netgear D7000
mickr62
Re: Netgear D7000
The link given states firmware for D7800 not D7000 Will it work with that.
Mickr
dickelliott
Re: Netgear D7000
Hi, The netgear guy I was talking to told me that this firmware update would also work on the D7000.
As yet I havn't purchased the router, need to save up a bit and rob the piggy bank first. I will not leave it too long though cos the Plusnet hub 1 is pretty useless comoared to the netgear router that i had before. unfortunately my old netgear didn't support IPTV.
Hopefully someone will buy one, update the firmware and confirm that they can get all the youview channels including the internet ones........... time will tell!!!
philbev
Re: Netgear D7000
I have a Netgear R7000 which is basically the same as the D7000 without the VDSL. Have to use an Openreach modem with mine. Works fine with Plusnet TV (with the latest updates.
