Nat Geo Keeps breaking up
dickelliott
Hi Community members,
Over the past 3 or 4 days my internet channels keep breaking up. Last night nat geo was hardly watchable with the picture and sound continually breaking up. before the past few days everything was fine. Have re started youview box etc but this morning it's still doing it but not quite so bad.
Internet connection is fine with download speeds nearing 60 Mbs so it can't be that.
Netgear router Nighthawk d7800 worked straight out of the box with plusnet iptv so i doubt it's that either.
Has anyone else had this probem and does anyone have any ideas how to fix it
Thanks in advance
2 REPLIES 2
dickelliott
Re: Nat Geo Keeps breaking up
By the way, using ethernet cable
SpendLessTime
Aspiring Hero
Fixes: 82
@dickelliott
I would suggest setting up a Thinkbroadband quality monitor to see if you have packet loss.
If you do then this thread at https://community.plus.net/t5/Fibre-Broadband/High-packet-loss-and-other-DNS-issues/m-p/1354749#U135... may help.
