Moving from Plusnet
boise7
Moving from Plusnet
Thinking of moving from Plusnet after several years but have a Plusnet Youview box with many hours of recorded programmes. These recordings are not from Plusnet Internet channels but the mainstream free-to-air channels.
If I move suppliers does this mean that I have to return the Youview box? or can I pay a fee to retain the box for future use?
Any help would be appreciated..
10 REPLIES 10
Fixes: 203
Re: Moving from Plusnet
https://community.plus.net/t5/TV/Do-you-keep-the-Youview-box-when-you-leave-Plusnet/td-p/1369882 should help
boise7
Many thanks, MisterW.
wisty
Fixes: 8
If you move to BT and take up their BT TV product, a factory reset (retaining recordings) on your existing YouView+ box will make it work with BT. At least that's what happened to me. You don't get BT's 4K channel, but everything else seems to work.
Fixes: 1,148
Welcome to the community forums @boise7
I'm sorry to hear you're thinking of leaving us. Mind if I ask what's swaying your decision?
boise7
I am just seeing how I stand should I wish to join TrueSpeed which is looking to provide FTTP in our area in the near future.
Fixes: 1,148
Ah ok. Those FTTP speeds are pretty nice. Is there a WBC FTTP product showing as available at www.dslchecker.bt.com which you could order through us?
boise7
Yes but your fees are extremely high since it is 'on demand' and any request is treated as a one off.
Truespeed are targeting rural communities in SW England for FTTP and will only install where 30% of community takes up the offer thereby making it cost-effective should it happen.
I don't believe BT are interested in rolling out FTTP, rather than 'FTTP On Demand', generally unless you know otherwise.
Jaggies
Unless I missed a change, Plusnet FTTP customers aren't able to order a TV service, are they?
Fixes: 1,148
That’s a good point @Jaggies I’ll admit I did forget about that. Sad
Mustrum
Fixes: 60
And you both seemed to have missed the point that only FTTP on Demand is available. The OP seems to be talking about a private FTTP provider.
