Limited channels shown via Aerial
Sara82
Having started You view last summer with problems accessing aerial channels (previously watched free channels on TV without an issue) we were accessing some channels but then 'lost' them some months back. We've been watching our TV through our sky box which means we are paying our plusnet bill for nothing . Does plusnet have a service to check the aerial , etc ?
4 REPLIES 4
friendlyhosting
Re: Limited channels shown via Aerial
 I would check this page https://www.freeview.co.uk/channels-at-your-address
This will give an indication of which Channels you should be able to receive via your aerial.
Gel
Aspiring Champion
Fixes: 25
RandallFlagg
Fixes: 75
HI @Sara82
Thanks for getting in touch.
Just a quick reply to confirm that the advice you've been given by our fellow community members is correct. Freeview availability can tend to vary from area to area and from time to time. If you check the availability using the links provided and update your channel installation, this should help.
Best wishes,
Dave
Sara82
Advisers at Plusnet really do give amazing support over the phone ... I just wish it was easier / quicker to speak to them
