Leave plusnet TV
tolmie35
Leave plusnet TV
Can you guys advise if I can leave plusnet tv since fox hd is going and that was one of the channels I wanted, I plan to keep my bb with you. I beleive BT customer can leave.
3 REPLIES 3
pwatson
Re: Leave plusnet TV
tolmie35
Not entirely clear, I'll phone up and see if I can cancel.
Oldjim
Fixes: 63
I thought this was fairly specific
10.3. If any of these changes are to your material disadvantage (even after we've offered replacement content or reduced your charges) you can cancel your service as set out in paragraph 18.3 of the Standard Terms. Where a change only affects an additional channel pack, that is not included as standard as part of the service, then you'll only be able to cancel that channel pack as set out in paragraph 18.3 of the Standard Terms.
unless it isn't part of the standard channel pack
