Is there a solution to the discontinued Youview App?
Baldricky
Fixes: 6
Hi
I tried finding it on https://community.plus.net/t5/TV/YouView-app-removal-Remote-Record/m-p/1705856 and became hopeful on https://community.plus.net/t5/TV/Using-the-BTTV-app-for-remote-recording/td-p/1722855 but suffered from brain overload.
It was a very useful App (not that I used it very often) and I thought I could uninstall it on my iPad and reinstall it. Only to discover it no longer exists.
The BT App, despite being told otherwise, does not work for non-BT customers - unless I've got something very wrong.
So, is there a 'simple' solution?
I haven't been able to find a definitive statement from Plusnet. I'm sure there must be one somewhere.
Cheers
5 REPLIES 5
PowerLee
Re: Is there a solution to the discontinued Youview App?
I very much doubt it seeing as Plusnet are discontinuing there TV service.
Once everyone is out of contract it won't be long before Plusnet pulls the plug completely.
Fixes: 1,285
The BT TV app works for setting up recordings.
What issues are you encountering?
Baldricky
Fixes: 6
@dvorak
RE: The BT TV app works for setting up recordings. What issues are you encountering?
Not being a BT customer and with the BT TV App not recognising my email address I originally gave up on it - too soon, it seems.
After seeing your message I thought there must be a way of getting it to work. So I decided to persevere with it and after quite a few attempts I managed to login and got the TV listings page up. I then linked it to my Youview box and selected a programme to record.
Success! I really did have 'something very wrong'.
Thank you for responding to my message (and in a constructive manner).
Rick
Fixes: 1,285
You don't actually need to log in - you can link your youview box without it.
Baldricky
Fixes: 6
That will make it even easier to use! Smiley
Cheers
