Internet channels slightly jumpy.
garpunkal
Hi.
Love the new plusnet TV but I've noticed the internet channels especially fox HD. Are slightly jumpy.  Mainly noticeable on animated TV shows.  Is this expected or can anyone give me advice why this is happening ?
Thanks.
23 REPLIES 23
ricke17
Re: Internet channels slightly jumpy.
Are you using powerline adaptors?
Fibre Broadband 80/20, Netgear D7000
garpunkal
Yep. My TV is a sony kdl 40ex603 with only a 50hz refresh rate.
ricke17
What brand/make are the powerline adaptors?  Has this problem only just started?  What router are you using? I gave up using them and now connect using an ethernet cable from the router to the youview box and all is ok.
garpunkal
They're tplink nano adapters.  Most of the time it's fine its just very slightly jittery when watching family guy.  Like its a refesh problems. A direct cable is going to be difficult to achieve for me though.
ricke17
Hmmm, have you tried resyncing them?  How far is the router from the youview box?
garpunkal
Yeah. Other channels like discovery HD is fine.  Just fox is particularly jittery when watching animated shows.  Maybe I'm just being picky.
garpunkal
Route is upstairs about 15 meters away.  Watch films over network all the time and no problem.  Using the Asus rtn66u router.
ricke17
Hmmm - I use a flat ethernet cable which I have tucked under the carpet - works a treat.
garpunkal
Yeah looking at one of those.  U not getting any jittering on family guy on fox HD?
ricke17
is it on now? I can take a look.
FYI: This is the flat ethernet cable I bought, pricey but it is shielded: http://www.amazon.co.uk/gp/product/B00M7UAHTU?psc=1&redirect=true&ref_=oh_aui_search_detailpage
garpunkal
Normally on later.  Thanks for link.
If you have fox HD just take a look during adverts and see if any of the text is slightly jittery.  That's what I'm getting.
ricke17
I have set it to record tomorrow night - I will take a look and get back to you.
garpunkal
Brilliant.  Thank you.
thegame2k0
For me FOXHD has been ok i recorded quite a bi from it and never have and judder. I'm using a 20 metre ethernet cat5.
