Increase volume from Youview box
JamesE
Is there some means of increasing the sound level output from the box? I set it up to control the TV volume when I first got it but it's a bit quiet - lower than other peripherals and I would like to increase its intrinsic level. You can alter other Humax boxes' output, I would have thought that there would be a way but I can't find it.
4 REPLIES 4
DS
Champion
Fixes: 22
Re: Increase volume from Youview box
You could try this:
Press the Y button -> Settings -> Picture & Sound -> HDMI Sound and select Surround and then back to Stereo
IIRC other users also had to change the S/PDIF Sound from Stereo to Surround and back to Stereo.
The first part worked for me.
KevinA
Press and hold the AD button (next to zero on the remote) and whilst still holding the AD button use the volume buttons also on the remote this will increase and decrease the actual youview box volume.
JamesE
Many thanks, Kevin, worked perfectly. Where did you find this information (in case there's something else I've missed)?
JamesE
Just told myself to RTFIB. Found it at the bottom of the page which gives instructions for making the vol. buttons control the TV.
