Impossible to load channels of my IPTV
pierrebagaria
Tried to factory reset the router, did not work.
Checked on the forum but there was no sign of this being fixed.
I tried to use the IPTV on 4G on my phone and it works perfectly fine. When connecting to wifi the channels don`t load. Thanks in advance for your support
went in the log this is the kind of messages I obtain:
14:03:30, 07 Mar. IN: BLOCK [16] Remote administration (ICMP type 8 code 0 111.161.35.146-​>146.200.134.32 on ppp3)
14:03:04, 07 Mar. IN: BLOCK [16] Remote administration (TCP [24.90.52.60]:51710-​>[146.200.134.32]:80 on ppp3)
13:58:33, 07 Mar. IN: BLOCK [16] Remote administration (TCP [111.61.52.53]:23685-​>[146.200.134.32]:8080 on ppp3)
13:54:53, 07 Mar. IN: BLOCK [16] Remote administration (ICMP type 8 code 0 139.162.189.5-​>146.200.134.32 on ppp3)
13:50:19, 07 Mar. IN: BLOCK [16] Remote administration (TCP [38.89.139.148]:43019-​>[146.200.134.32]:22 on ppp3)
1 REPLY 1
VileReynard
Fixes: 20
Re: Impossible to load channels of my IPTV
Ignore the log.
It's various people trying to discover if you are a server running services that they could attack and its spread over many minutes. Your firewall blocks these attempts anyway.
