IPC6023 Error!
jimhrvy
IPC6023 Error!
All my subscribed channels are suddenly NOT working! This is the error fault number associated with it.
I have done everything as described, as far as resetting my Youview box,  all of no avail.
Interestingly, BT Sport app works perfectly on my iPad, Windows Laptop, and an android box attached to my television!! All of these pieces of kit use the same access point to the internet; The only piece of kit with the fault / error is the Plusnet Youview box!!!
Doing a google search shows me that this error has history back to 2014, with BT, TalkTalk as well as Plusnet.  It appears that there is no real satisfactory solution to this problem  -  or is there?
I don't see any point in contacting Plusnet Support, I only wait hours on the 'phone while they try to find the right "expert". Is there anybody on this forum that has any constructive and useful to offer?
My only real option is to wait for my contract to expire and then leave plusnet; I wonder what the Advertising Standards people would say about the Plusnet Adverts?!!!
Jimhrvy
4 REPLIES 4
Re: IPC6023 Error!
@jimhrvy - Funnily enough I had IPC6023 errors when I was using my own ASUS RT-AC68U Router with Plusnet TV (even with correct multicast settings).
Each IPTV channel would work for around 2 minutes then end in an IPC6023 error. I tried rebooting, then resetting, my YouView+ box to no avail and in the end fixed it by using the supplied Plusnet Router. And when the wi-fi on it proved too slow for me, I upgraded to a BT SmartHub and haven't had a single IPC6023 error since.
So, if you're using a 3rd party router, try using the provided Plusnet one and, if not, then I'm out of ideas unfortunately.
jimhrvy
Re: IPC6023 Error!
Funnily enough, I had just gone back to my plusnet router this very week!!
The Fault(!!) as you described it happened to me. I had been relying in the BT Sport app on my android smart tv box, when I tried the Plusnet box again, and instead of the error message straight away, as you described, it was ok for a moment or two, and then bombed out! That was the clue I was looking for, re-installed the Plusnet Router and everything was OK!!
My research (!!) on the internet has shown that this error is a system fault; no iISP has ever come up with a permanent answer, and it still occurs, as we've found out. Solutions have varied from a 'third party' piece of equipment at the exchange to various software 'updates'.  It seems that the system itself is at fault and nobody is prepared to investigate and find an answer. Asa retired IT Professional who has been a tech support manager during my career, I find that attitude very, very poor.
On another note, how are you finding the BT Smart Hub? That was one of my considerations when I was switching away from the Plusnet Router, and like am not all that happy the Plusnet's 5 MGhz performance.
Moderator's note by Mike (Mav): Removed quote tags.
Re: IPC6023 Error!
@jimhrvy - I think the problem, as you've noticed, is that the IPC6023 error seems to signify a general fault, and working out which issue caused it is a problem. The official YouView page for this error shows that it could be caused by a number of factors, and resetting or rebooting your box often doesn't solve it (it didn't for me).
Luckily, in my case, swapping my ASUS router for the Plusnet supplied one fixed this (my ASUS worked perfectly with BT's IPTV service when I had it).
Regarding the BT Smart Hub, it's been very stable for me - which I gather wasn't its strong point when it was first released - and works well in my medium sized flat. It can go weeks without rebooting - I've noticed no drop-outs since using it - and its wi-fi is very strong (from what I've read, it has more antennae than the Home Hub 5, on which the Plusnet router is based).
I bought mine new for around £60 on Amazon (it's a bit more expensive on there now) but often goes for less on eBay - though obviously this is the riskier route.
I found this post on these Forums very useful when setting it up on Plusnet's network: https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1415464#M312705
thecrows
Re: IPC6023 Error!
Hi Having recently received a Youview box we were also receiving this error. Disappointingly it seems to be a catchall error message for numerous different broadband related issues BUT in our particular case similar to someone here the subscription channels were affected but the Freeview channels were all working fine.. We followed the instructions in the help, rebooted the router, the Youview box, all to no avail then I put in google the error message and the router manufacturer and someone on a BT forum seemed to have very similar issues with an identical router so "IPC6023 and Draytek router".
https://community.bt.com/t5/YouView-from-BT/IPC6023-Draytek-Router-Solution-for-you/td-p/1782084
I logged into my router and went to applications section within my Draytek and enabled the IGMP Proxy.
Instantly the subscription channels fired into life... BUT I then immediately lost access to my router and WIFI on all my devices... I turned off the YOUVIEW box and it all came back. I went back into the router and ticked one more option to enable IGMP snooping and now happily partner is watching one of the subscription channels and I am on the internet. Job sorted and in only a few days of set up.
