IP chanels breaking up
SteveA
Getting random break up and the "There are problems" messages across all IP channels at random. TV box and router and OR box all restarted and its not making any difference.  Speed checks not reporting any problems.
Last time this happened it went on for weeks and I had the box and the router replaced (new router turned out to be completely useless so I sent it back).  Never got to the bottom of the problem last time - they thought it was a problem sending resend messages back for dropped multicast packets but nothing was ever really pinned down- I'd raise a ticket but now they've made that so awkward..
Anyone else seeing this problem?
14 REPLIES 14
adamwalker
Fixes: 128
Re: IP chanels breaking up
Hi SteveA,
Diagnostics aren't showing me any connection problems. Can you try dropping the broadband connection (i.e powering the router off, then back on or log in and disconect/reconnect).
Let us know if that makes any difference.
 Adam Walker
SteveA
Hmm - well something glitched on my router - I was getting less than 3MB download (even though I'd checked it earlier) and just about no upload....
I've restarted it and will see how it goes.
adamwalker
Fixes: 128
That'll be the culprit. I'm guessing a reboot sorted that and fixed the issue?
 Adam Walker
SteveA
Hopefully - now just got to work out why I get this error when I attempt to post to the forums:
npr
Fixes: 8
SteveA
Well it fixed it for a bit - now getting picture break up and sometimes a completely black screen for a second or so but with no error messages being displayed..... Speed test (just run) shows no apparent problems....
npr
Fixes: 8
Which router do you have?
Is there any other activity on your network, eg p2p software running other downloads / updates etc.
SteveA
TG582n
No software that's not normally running - but no P2P at the moment and nothing downloading.
npr
Fixes: 8
Try this:
In the routers network device settings, identify the Youview box and for that device tick "always use the same IP address".
Reboot the youview box and see if that helps.
SteveA
I configured the YouView box to use a static IP address last time I was having issues like this...
npr
Fixes: 8
IMO that's not such a good idea with the TG582n. It can lose track of connected devices when they go to sleep mode for long periods. By ticking "always use the same IP address" in the routers settings for the device it ensures the router keeps track of the device. I suggest you put the youview back on a dynamic IP and then make the above config in the router.
Note:
Printers and connected TV's often appear to suffer from this issue.
SteveA
DHCP isn't being done by the router - DHCP is being done by a server which has a specified range for dynamic addresses and the YV box is sitting in another range that I only put certain devices such as the YV box, the wireless printer and a couple of wireless access points.
npr
Fixes: 8
Are you sure that's not breaking IGMP / Multicast. Undecided
SteveA
The YV box is set with its own IP address, the fixed IP address of the router as its gateway and the DNS is set to the PN DNS servers.
Its been set this way since I got the box and its been fine apart from two periods of misbehaving like this.
