How to cancel BT Sport
Can you tell me how to cancel BT Sport as there is no help on-line. Thanks.
3 REPLIES 3
Fixes: 126
Re: How to cancel BT Sport
Hi there, I've opened a ticket on your account which we'd just need you to reply to so we can remove access to the app for you: https://www.plus.net/wizard/?p=view_question&id=195443099
Please reply back here once you've responded and we'll pick that up for you.
 Adam Walker
Yes, please remove BT Sport.
Fixes: 76
@thepetman,
You need to click the link provided above and add the removal comment. When you click the link you'll need to login to the member centre with your username and password, enter your reply in the comment box, click send and we'll get it picked up - it just ensures the person requesting a change to the account is actually the correct person.
 Joe
