How long before I can manage my TV Package
mojorisin
Had the You view box setup since yesterday but still getting this on the management portal online
Sorry, your YouView TV from Plusnet service isn't ready yet.
Please come back once you've received your set top box and plugged it in.
13 REPLIES 13
thegame2k0
Re: How long before I can manage my TV Package
Go to channel 307 on your youview box and select "set up this channel now"  you just click the blue ok or set up now button in middle of screen and that will activate your box and channels.
mojorisin
the channels are already activated just when i go to the website where it lets you add and remove channels it says they aren't active yet ?Huh
MatthewWheeler
Fixes: 405
I'm just checking this for you.
 Matthew Wheeler
mojorisin
Did you have any luck
MatthewWheeler
Fixes: 405
We're aware of a issue that's causing this affecting certain customers.
We'll get it fixed as soon as we can.
I'll keep a eye on it and sort it as soon as I can.
Sorry for any inconvenience.
 Matthew Wheeler
mojorisin
no problem thanks for looking
mojorisin
any update on this still seems to be the same
MatthewWheeler
Fixes: 405
Still looking into it I'm afraid.
 Matthew Wheeler
mojorisin
Also get this when viewing my usage ?
Sorry, there's nothing to show at the moment.
This might be because your account is new, or your usage has been reset for a new billing period.
It can take up to 4 hours for your usage to show up - please try again later.
its been like this since the Plusnet TV was added
mojorisin
any update this is still not working
MatthewWheeler
Fixes: 405
It could be a few more days yet.
Sorry for the delay.
 Matthew Wheeler
mojorisin
all working now cheers
MatthewWheeler
Fixes: 405
Glad to hear it's working Smiley
 Matthew Wheeler
