Handbook for Youview+ STB
moonrakerz
Have just received my Youview+ STB, connected it up as I thought it should go - everything works absolutely fine. When I was clearing the debris away I discovered that there was no handbook supplied with the box. Does any one know if there is meant to be one - or is there one online ?
There is no model number on the unit other than "Humax" on the rear. On the box (cardboard one !) it saysDTR - T2120/500G/Plusnet.
I would particularly like to know if it is possible to control my TV from the remote. At the moment I appear to be able to turn the TV on - but not off and to switch HDMI inputs by use of the power button on the remote.
5 REPLIES 5
Fixes: 1,285
Re: Handbook for Youview+ STB
welcome to the forums Smiley
user guide can be found here http://www.plus.net/support/pdf/tv/YouView+-Plusnet-User-Guide.pdf
moonrakerz
Many thanks ! You obviously know your way round the website a lot better than I do .............
PeterLoftus
He's a  forum moderator  Shocked
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
moonrakerz
Gosh ... I spotted that too  Roll_eyes
Jaggies
@moonrakerz
And to answer your other question, yes you can control the TV from the YouView remote.
