HD Channels on aerial
Chrisvesey
Is there any way of getting the channel numbers displayed with youview
Chris
12 REPLIES 12
MatthewWheeler
Fixes: 405
Re: HD Channels on aerial
Hi Chris.
I've provided this information below for you
Channel Number Channel Name
101
BBC One HD
102 BBC Two HD
103 ITV HD
104 Channel 4 HD
105 Channel 5 HD
106 BBC Four HD
107 BBC News HD
108 Al Jazeera Eng HD
109 Channel 4 1 HD
110 4seven HD
111 QVC HD
112 QVC Beauty HD
113 RT HD
114 Quest HD
 Matthew Wheeler
Chrisvesey
Is it possible to see the channel numbers displayed on the guide
MatthewWheeler
Fixes: 405
They should already be in your TV guide if they're available to you
Have you checked here to see what's available and have you tried retuning the box?
 Matthew Wheeler
Chrisvesey
The TV guide tells you the name of the station but not its number although you can retune by putting the number in, doesn't make sense
Chrisvesey
The channel numbers have suddenly appeared on the youview guide 🤔 all we need now is the numbers to appear on the app.
MatthewWheeler
Fixes: 405
You'd need to contact YouView directly regarding that as the app is maintained by them
 Matthew Wheeler
Chrisvesey
Thanks 👍
Chrisvesey
Just discovered that if you click on "now and next" in the menu the channel numbers are there👍
ruffage
My HD channels stop after 105. Are the rest only in the HD pack?
Shep41
Fixes: 4
It could be that your signal isnt strong enough to receive all the hd channels
DS
Champion
Fixes: 22
Could you have hidden those channels some time ago?
Blue 'Y' - settings - TV channels - unhide channels. It should show the number of channels you've previously hidden. But use this with caution, an update some time ago stops you from hiding them or further channels again.
The other thing to do is retune.
Almost the same steps if you didn't navigate using the above, but select retune channels.
Mine are all there, just checked during this reply.
ruffage
Yes it was this.  Think I was tuned to a lightweight transmitter.  Clear skies today so re-scanned and picked up the missing HDs from another transmitter.  Proof is whether I can use them when the weather's bad.
