Good start so far
Mayfly
Seasoned Pro
Good start so far
Ordered PN TV on Friday at 10.00 with powerline adaptors and they arrived at 9.00am.  Just waiting the new router now.
27 REPLIES 27
Mayfly
Seasoned Pro
Re: Good start so far
Ah a slight technical hic-up the powerline adaptor only has one 1 ethernet port, I didn't realise that, I need one for the TV and want one for my laptop.
Can you buy singles I can only find the Flex 500 in Kits of 2.
ashgeo
you could use a switch like this: http://www.dabs.com/products/netgear-gs105-5-port-gigabit-switch----2X1X.html?refs=50542&src=2
I've used Netgear switches on powerlines and they have worked fine.
Good luck!
Mayfly
Seasoned Pro
Could you explain how these work please? I can't seem to find the info when reading about them. I assume the switch plugs into the powerline?
Alternatively could I buy another set of the 500 flex adaptors which would also give me a spare?
ricke17
You will probably need to buy an additional ethernet cable to connect it to the powerline adapter near your TV.  Essentially, think of it like a 4-gang extension lead for your products.
You plug it into the powerline adapter near your TV then connect the various devices to it.
I gave up with powerline adapters for my pn tv and opted for a wired solution.
Fibre Broadband 80/20, Netgear D7000
PeterLoftus
I use one of these  Smiley
Downside is the flashing lights which keep the aquarium fish awake  Roll_eyes
http://www.solwise.co.uk/net-powerline-pl-200av-4pe.html
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Mayfly
Seasoned Pro
At the moment I use a Devolo with 4 ports [Only use 2] had it a few years but it keeps losing wifi when I use my tablet and I have to keep resetting it. It may just be easier to ask PN if I can send the BT powerlines back and buy a multiport one.
ricke17
Yeh - give them a call.
I tried these ones: http://www.amazon.co.uk/gp/product/B00X59GJGC?keywords=tp%20link%20powerline&qid=1439883120&ref_=sr_... but found the wired solution better.
Rick.
Mayfly
Seasoned Pro
Just spoken to customer services they won't accept them back!  Angry
So anyone buying them be aware that they are only single port, as I wasn't.
Perhaps I should change the title to 'Not so Good start so far'!
PeterLoftus
All is not lost  Wink
I mix and match I have some solwise 500 and TP Link 200 units as well as the unit I posted earlier. They all work happily together. So I have the desktop in the attic, the smart telley in the spare room as well as the media centre in the lounge all connected up on powerline adapters.  Cool
I'm sure you'll find a use for them  Grin
ricke17
Quote from: Mayfly
Hmmmm, try a switch then mate?
Mayfly
Seasoned Pro
Yeah I'll try them first with the TV on ethernet and laptop/tablet on wifi.
I game and find I keep getting 'slow connection' on wifi but these may be better, other wise I'll buy a switch. I take it from a post above any make can be used?
Thanks all for your replies.
ricke17
What router are you using?
Mayfly
Seasoned Pro
At the minute PNs Technicolour 528n but I am waiting for another one compatible for the TV side of things.
ricke17
Ah ok - what router are you waiting for?
