Forced software update
PowerLee
Was using the UK TV Play app this morning when the YouView box decides to force a software update on itself - really annoying.
Shame You View can't install software during the night / when the box isn't in use.
I know it doesn't really matter now seeing how Plusnet have sacked off its YouView service.
1 REPLY 1
Fixes: 1,291
Re: Forced software update
Mine updates overnight, maybe the power settings you're using?
