Feature request: Enable YouView remote to change code to avoid operating other Humax devices.
- TV
- Feature request: Enable YouView remote to change c...
25-11-2019 5:13 PM
My oldest Humax box, a Foxstat HDR, allows me to select a code (1-6) to 'pair' it with its remote.
My understanding is that there is no equivalent feature in the PlusNet YouView box (or the BT one) and that the code is preset to 1.
I now have a third Humax box - a TN8000HD (French TNT Sat) and that has the same problem. So both remotes operate both boxes.
These Humax variants are proliferating! Please could you include this feature in the next f/w update.
(And I would ask in the TNT forum if there were one.)
Thank you for reading.
Re: Feature request: Enable YouView remote to change code to avoid operating other Humax devices.
26-11-2019 10:32 AM
Thanks for the feedback @DavRo
I've passed this onto the correct team to review internally although I can't guarantee a change.
Apologies for the inconvenience caused.
26-11-2019 3:29 PM
Thank you.
Although it occurred to me that unless this facility is already built into the remote control I doubt if it could be fixed in the firmware of the receiver.
- TV
