Eurosport problem
Mayfly
Seasoned Pro
Eurosport problem
Anyone else having a problem with Eurosport
Keeps telling me 'Sorry we've detected a problem showing Eurosport1' [&2]
and gives what I assume is an error code BTV-420
Have rebooted but it's just the same, other channels are fine.
3 REPLIES 3
Fixes: 1,291
Re: Eurosport problem
seems to be working here ok.
w23
Fixes: 4
'BTV' appears to be BT Vision (I can only assume that Plusnet use the BT Vision platform), some (limited) 'assistance' on BTV codes here: http://bt.custhelp.com/app/answers/detail/a_id/47437/~/btv-error-codes-on-youview
It appears to suggest something along the lines of:
* Restart your router
* Restart your YouView box
* Check your software version is up to date. To do this go to Settings > Device Management > Software Update and press OK
* Check your On Demand players are up to date. To do this go to Settings > Device Management > Update On Demand Players and press OK
* Contact Support
Call me 'w23'
Mayfly
Seasoned Pro
Back up after doing a software update, tho' it had only done one on the 14th.
I had been watching the cycling all morning then the channel just went down.
