Discovery HD Channel 376 and IPC6023
Tibbie
Hi anyone have some wise words
All IPTV channels are good, except Discovery HD, where the dreaded IPC6023 is displayed,
Is this channel a higher bit rate ??
11 REPLIES 11
ricke17
Re: Discovery HD Channel 376 and IPC6023
What router are you using and how is the youview box connected to it?
Fibre Broadband 80/20, Netgear D7000
Tibbie
Asus RT-N66U running 3.0.0.4.378_6117
Cabled connections
ricke17
Have you configured it correctly for multicast?
Tibbie
Still seeing this problem, updated R66U router to 3.0.0.4.378_7410
YouView box on cabled LAN connection
Every other IPTV channel seems fine
Channel 376 now crashes the router !!!
I have no idea what is happening here  Sad
ricke17
Very odd - mine is ok (am using a Netgear D7000).
Have you rebooted the YV box?
Tibbie
Yes Everything rebooted, to confirm only channel 376 is not working.
Plusnet is there something different about this stream ?Huh
I sync at 74Mbps and enjoy high 60's
ricke17
Hmmmm - not sure mate - hopefully pn can figure something out
MatthewWheeler
Fixes: 405
There's no issues we're aware of.
The only things I can think of is trying our router or a reset of the Youview box.
 Matthew Wheeler
Tibbie
I can confirm the issue lies within the ASUS RT-N66U, the Sagemcom router is ok, however for me this opens a huge issue, the Sagemcom is horrible for wi-fi, this is one of the reasons subscribers use third party non supported kit.
So my question to the Plusnet team is please qualify a decent router that delivers the requirements that many users need in terms of good wi-fi
Tibbie
After a little digging I uploaded merlin v378_55, then did a reset on the ASUS and so far so good, whether the reset would have worked on the old version, one will never know
ricke17
Quote from: Tibbie
I have more chance of winning the lottery than pn bringing out a half decent router!
Good luck!
