Constant break up
thegame2k0
Constant break up
On the plusnet Youview freeview channels i am having nothing but constant break ups the internet channels are fine, i've changed the ariel lead and still get break ups.
I tested both leads on my tv which has freeview built in and there was not one single break up which indicates it is the youview box.
Anyway that's no biggie as the internet and on demand channels are fine so would it be ok to just disconnect the ariel from my Youview box and only use the internet channels as they are what i mostly watch anyway.
3 REPLIES 3
pwatson
Re: Constant break up
Try it without the aerial but I think you'll find that the EPG data is only available over the air so won't update.  I may be wrong and the Youview system may also allow for downloading the info from the Internet...
DaveyH
Champion
Fixes: 12
I dont have mine connected to an aerial, I get EPG data for the IP channels.
thegame2k0
Thanks guys i will disconnect the ariel Smiley
