ClassicFM
philbev
ClassicFM
Could someone confirm that ClassicFM is available on PN?
Regards
Phil
2 REPLIES 2
pwatson
Re: ClassicFM
See here for a guide to the channels available
http://www.a516digital.com/p/youview-channel-listing.html
All channels outside the 225-600 range re received through your aerial and having nothing to do with Plusnet.  The channels in the 225-300 range are delivered via the Internet but are not part of any ISP provided subscription TV service (and many don't work on a Youview box).
Channels 301-600 are part of ISP subscription packages and you'll note that the channels available are ISP dependent.
ClaasicFM is on channel 731 and is part of the COM5 multiplex transmitted by most (but not all) TV transmitters.  There's an availability checker here to see if this is available where you live:
http://www.freeview.co.uk/availability
philbev
Re: ClassicFM
I know I can get ClassicFM on my Freeview TV so now I can safely assume it will be available on Plusnet. Thanks for your help.
Regards
Phil
