Channels Missing
tolmie35
Channels Missing
Can you guys explain why I no longer have the channels I subscribed to such as Nat Geo, History etc and why suddenly I have received an email about suddenly subscribing to BT sport when in fact I've always had it.
13 REPLIES 13
ricke17
Re: Channels Missing
Mine were missing this morning - doing a software download cured it - go to your settings menu on the YV box, then to Device Manangement and up to software update then click on the 'get update' icon.
Rick.
Fibre Broadband 80/20, Netgear D7000
tolmie35
Thanks Rick I'll give it a bash when I get home.
ricke17
It should work, they have updated the service status too: http://www.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=tv
allykat72
Since this stupid update today.. I have no channels between 254 and 601?? where is MTV music gone?  Embarrassed
ricke17
Have you tried doing a manual software update?
garpunkal
I had the same problem, all my internet channels were missing.
Plus.net did a test on my line and said no problems were found... still missing channels...
Chris
Legend
Fixes: 169
There are some issues with Internet channels, however if you perform a manual software update on the box you should get these back.
jjc
This fixed it  Smiley however if I was not part of this forum how would I have found out?
Once the problem was found could a software update not have been triggered?
ricke17
I guess we live and learn and in future we should do a software update if it happens again.
Chris
Legend
Fixes: 169
It was posted on to our service status page, status.plus.net
SteveA
So what happened that meant that only manually forcing a software update fixed it... .it sounds rather a drastic solution.
hex
I doubt the manual update was the only way to resolve the problem - but leaving the box to do its own check may have meant it would take a day or two to check and download/apply it.  I don't think plusnet have any way to force the boxes to update from their side.
SteveA
Quote from: hex
My point is what on earth was going on that the only fix was a software update?  Automatically downloaded or forced by the user it seems a rather drastic fix for an apparently unexpected outage.
