Channel packs
Peter111
Channel packs
I've had plusnet tv for about a week now, how do I manage channel packs? If i log in to the member centre I can't see anything regarding tv or channel packs.
Many thanks
2 REPLIES 2
MatthewWheeler
Fixes: 405
Re: Channel packs
Sorry to hear you can't manage your TV packs.
It can take up to 10 days for you to be able to do this from when you first set up your box.
 Matthew Wheeler
stereohaven
Fixes: 4
Re: Channel packs
As mentioned above, it takes a while for the menu option to appear. When it does it looks like this:
