Channel Problems
- TV
- Channel Problems
Channel Problems
16-01-2020 12:34 AM
Is anyone else having problems with History, H2 and C&I channels tonight - it's like someone has pressed pause on the stream.
At the moment - History is just a picture of three jet fighters
H2 of a picture of someone called "Dr Billy J Johnson"
C&I is a picture of someone called "Steve Williams"
History HD is a picture of a white disc on what looks like a blue sky blackground
C&I HD is a picture of blurry door handle
These seem to be the only channels affected.
Re: Channel Problems
17-01-2020 1:36 PM
Thanks for getting in touch @pboyde
I've checked and there's nothing we're aware of that would cause this.
Has it happened again or was it just a one-off?
17-01-2020 3:54 PM
Normal PN issues then.
do not expect them to fix anytime soon.
they will just come out with excuse after excuse and just sit on the problem in the hope you will just go away.
