Changing Youview box to another tv
riky
Looking ahead here
But  can i simply take my youview+ box downstairs onto another tv without having to activate/change anything ?
?????????????Huh
2 REPLIES 2
Den1
Re: Changing Youview box to another tv
Yes you can no worries, the only thing you cant do is run two youview boxes on the same connection.
robinlee
Thanks for your answer. It helped me a lot.
