Change remote frequencies?
Lovol2
Hi all
I've just got the you view box and the remote control interferes with another device that I have.
Is there any way to change the frequency of the view plus net box?
I have the recordable one made by humax
4 REPLIES 4
cegueira
Re: Change remote frequencies?
Is the other device a humax? If so you need to change the remote frequency on the non-youview box:
https://hummy.tv/forum/threads/using-more-than-1-humax-box-in-the-same-room.24/
I have done this with an HDR FOX T2 and it plays nicely with the youview DTR-T2110
Lovol2
Thank you for the reply. Unfortunately no it is not so I can't do that
cegueira
Ah, well the functionality to change the remote frequency is not available on the Youview box unfortunately.
Lovol2
Using a talk talk box has fixed my problems. It's slower. But works.
