Cannot Remove BT Sport from YouView
cossie66
Seeing as it is impossible to email or contact support by phone after 8 PM, and no online support, can you please remove the BT Sport from my Account.
Many thanks
1 REPLY 1
Fixes: 1,145
Re: Cannot Remove BT Sport from YouView
Thanks for your post @cossie66
You should be able to manage your YouView channel packs through your account online.
However in this instance, it looks to be stuck in the billing system so I've added a credit to cover the cost of this for the remainder of your contract, the credit will come off your next bill.
I hope this helps.
