Btsport app login nightmare
Ndd9876
I’m not able to log in to my btsport app.
I’ve been going around & around trying to reset the btsports app password . No joy.
Ages online with bt support. No joy. Bt support says “it’s a plusnet problem”.
Then I found this link:
https://community.plus.net/t5/TV/BT-Sport-App-not-working-BT-ID-nightmare/td-p/1617987
Which seems very similar to my problem. Pls help. Missing my footie!
4 REPLIES 4
Ndd9876
Re: Btsport app login nightmare
Any ideas?
TheMightyAJ
Fixes: 85
Hi @Ndd9876,
I'm sorry to hear that you're experiencing this issue. Is the email address you're using to sign-up to the BT Sport App service associated with any previous BT accounts you may have had?
 Alex H
Ndd9876
Ah,ha. Yes...I have used the same email address for a bt broadband account in the past...
So what’s the fix?
RealAleMadrid
Seasoned Champion
Fixes: 39
I would suggest you use a different email address if you can.🙄
