Broken plusnet set top box
helenm76
Our planet set top box is not working. Have tried it on two TVs and the picture keeps flashing every few seconds with a black screen. Have reset but no difference.
Spoke to support, numerous people including technical for 3 hours. They said box is fine just needs retune. Obviously it's not a running issue as the channels are there in between the black screens.
Can a second hand box be used as a replacement add it's obvious plusnet have no interest in the issue. My main concern is will true extra packages work on another box? Would it need re-registering to plusnet?
At the moment it's unusable.
Helen
2 REPLIES 2
dave501
Fixes: 6
Re: Broken plusnet set top box
@helenm76 yes you can use a second hand box and no it will not need re-registering. I use a BT Humax DTR-2100 which works great plus the subscription channels also work fine….
helenm76
Thank you Dave.
