Broken YouView Box?
lenfish
Broken YouView Box?
Came home tonight to find the box in an endless reboot cycle of waking up, loading, waking up. Managed to get into the maintenance menu but when I select the options to do a factory reset it briefly flashes onscreen that it is resetting then immediately afterwards says the reset has failed. Is there anything else I can try or is destined for the knackers yard? Thanks.
Regards,
Len
8 REPLIES 8
Daniel28012
Re: Broken YouView Box?
Which maintenance mode reset did you pick as there are a few options.
lenfish
All of them!
Daniel28012
If that’s the case it’s safe to say that the box has had it.
HarryB
Fixes: 255
Hi @lenfish, I'm sorry to hear you're experiencing problems with your YouView box.
I'm afraid as it appears to be out of warranty, the options I'd have to advise of would be purchasing a new box from us at £199, or re-contracting for TV at which point we'd be able to provide a new box as part of the new contract.
If you'd like us to arrange for someone from our Customer Options Team to give you a call to discuss re-contracting, we'd be happy to pass this over to them for you.
 Harry Beesley
 Plusnet Infrastructure Operations Professional
lenfish
Harry,
Many thanks for the reply. I’d be grateful if you could pass this over to the customer options team. Thanks for your help.
Regards,
Len
Daniel28012
Just out of curiosity @HarryB can a in contract customer pay the £199 for a youview plus box anytime they like weather there existing box works or not.
RandallFlagg
Fixes: 75
HI @lenfish
Thanks for confirming - I've asked someone to contact you to get this sorted.
Best wishes
Dave
lenfish
Dave,
Many thanks.
Regards,
Len
