Broadband or Youview problem?
- TV
- Broadband or Youview problem?
09-01-2020 4:56 PM
Re: Broadband or Youview problem?
10-01-2020 10:04 AM - edited 10-01-2020 10:04 AM
Hi @smithydog I'm sorry to see you're having issues watching your subscription channels. With the error code you've got I've been looking into this and is there any way you'd be able to connect your YouView set top box directly into the router using an ethernet cable? This should narrow down where the issue may lie by ruling out the problem to be the powerline adapters/internal wiring.
Let us know how you get on
10-01-2020 10:11 AM
10-01-2020 6:05 PM
Thanks for getting back to me @smithydog
I'm looking into this with a colleague for advice on what the next steps are and I'll post back when I know more.
13-01-2020 1:58 PM
Hi @smithydog Sorry for the delay, I've discussed this with a colleague and I've tested your broadband for an issue which may be impacting your TV service and the tests aren't showing any issues with your broadband connection.
Looking at the previous fault you had a few months ago, it looks like following an engineer went out and fitted an 12db attenuator on to the aerial although it looks like this caused further issues with your Freeview channels. Unsure what resolved that to be honest as I can see we sent you a few checks but we didn't hear back afterwards.
If the problem is the same as last time and the steps you carried out then don't resolve the problem, I'm afraid we'd need to arrange another engineer visit to investigate this further.
Let me know if you'd like to go ahead and I'll be happy to organise this with you.
13-01-2020 8:07 PM
13-01-2020 10:09 PM
Hi @smithydog that's good to see even though we've not got to the bottom of the issue. Let me know if it does become a problem again though.
