Box arrived
jimrichards92
Box arrived
The youview+ has arrived this morning and imo I think the box looks nicer than the BT g4 box.
Everything is working but the downside is that I cant get IPTV to work with my router which is Netgear R7000 even though IGMP snooping is enabled. So its been unplugged and the plusnet F@st 2407n has been plugged back in and I can now watch the IPTV channels...
However I do have an issue with the HD channels where it is a bitch glitchy where the sound and video stop for a millisecond just enough for you to notice every few mins
2 REPLIES 2
Finguz
Re: Box arrived
Have a look in the R7000 manual.pdf at the bottom of page 42 and page 43.
There is more at the following link..
http://kb.netgear.com/app/answers/detail/a_id/25724/~/vlan-tagging-setup-for-nighthawk-router
Snowmatt
Re: Box arrived
Did you ever get this working using the R7000? I cant figure it out - i dont know what the Vlan enteries should be?
