Billion BiPAC 8800NL set up
robbiecollie
how easy is it to set up for plusnet youview box and also to monitor ping via the thinkbroadband monitor the supplied router does not allow ping monitoring
5 REPLIES 5
ricke17
Re: Billion BiPAC 8800NL set up
I posted this link to a thread (http://www.billion.uk.com/forum/viewtopic.php?f=19&t=3764I posted on the Billion forums, in a previous thread.
I have a Billion 8800AXL and followed the guide posted on that thread and am sat watching IPTV on the YV box with no problems.
In answer to your thinkbroadband monitor - I am not sure - maybe post something on those forums?
Rick.
Fibre Broadband 80/20, Netgear D7000
pwatson
Quote from: robbiecollie
If the 8800 is like my 7800X, WAN ping is enabled under Configuration-Security-Block WAN ping
Note that you'll need a static IP in order for the TB monitor to work
Marksfish
Seasoned Pro
Fixes: 4
Quote from: pwatson
No you don't. It is just inconvenient as you will have to create a new monitor if your connection drops and you are allocated a new ip address. Mine stays up for 10- 20 days at a time before randomly rebooting, then I delete the monitor and create a new one.
Mark
robbiecollie
Have been trying to register for the bullion forums tio view instuctions but cannot seem to be able to register you cannot view posted insructions without loging in
pwatson
