BTV-437 error subscription channels
charlieng01
Hi
Just wondering if anybody has actually found a fix for this that isn't the old turn it off and back on again?
I've opened a support case but the only advise i get is to reset or 'power cycle'.
I've tried changing the IP of my youview box manually. I know its not a connection fault because i can access my freeview channels through the ariel and stream through all my players and apps.
any help would be muchly appreciated.
5 REPLIES 5
Chris
Legend
Fixes: 169
Re: BTV-437 error subscription channels
Have you tried to power down the box and router for 1 hour to ensure this picks up a new IP address on reconnect?
charlieng01
Hi Chris
I have. I powered both down for an hour as advised and powered down overnight and neither worked.
Chris
Legend
Fixes: 169
Can you ensure that you've checked for software updates on the box via the menus please.
charlieng01
Hi Chris
Yeah, i've also checked for updates. All up to date. i can only presume its something plusnet side like they havent enabled me to be able to view these channels?
Fixes: 1,138
I've just raised a task (511033) with our database team to fix this for you. It can take a couple of days though, apologies for any inconvenience caused.
Anoush
