BT sport app
depechemode1986
BT sport app
Hi I've added the BT sport channels onto my Youview box for £5 a month.if I download the bt sport app on my mobile phone to watch BT sport, is it free to use or is there an extra charge to use the bt sport app service thanks
3 REPLIES 3
MatthewWheeler
Fixes: 405
Re: BT sport app
Hi there.
If you've took the BT Sport channel pack there's no extra charge to use the app.
 Matthew Wheeler
Interceptor121
Fixes: 5
Re: BT sport app
If you use it on mobile data you will use your allowance and could potentially be charges by your mobile operator
Alex
Fixes: 12
Re: BT sport app
Yes try to use Wi-Fi where you can (either home or public).
If you can't use Wi-Fi, then keep an eye on your data usage.
One thing I like about EE is if you go over your limit (I have done this when roaming), is it just stops working and nags to pay more money upfront to continue. So you have the option to say Yes/No without getting hit with high unexpected bills.
