BT sport app manage devices
Interceptor121
Fixes: 5
How do you manage your devices for the BT Sport app on Plusnet?
1 REPLY 1
stereohaven
Fixes: 4
Re: BT sport app manage devices
I don't believe you need to.
You can install/use the BT Sport app on as many devices as you like, subject to a maximum of two active streams at a time.
I believe that if you are a BT customer and use the BTTV app then you do need to manage devices (as I do with NOW TV), but it's not the case with the BT Sport app.
Confirmation via BT Customer Help can be found by clicking here.
