BT Sports ap . Your experience of.
russspur
I do have the BT Sports Channels on  Sky but as little used I am thinking of changing to the BT Sport Ap so I can watch on my Android tablet. Is the BT Sports ap any good ?
Russ
6 REPLIES 6
Fixes: 1,291
Re: BT Sports ap . Your experience of.
Moderators Note.
Moved to TV from Everything else
russspur
Russ
FttpPeter
It's very good. You can cast to a TV using a Google Chromecast or Apple TV. Being able to install it on unlimited devices is handy (compared to the 2 or 4 limit on the Sky Go app), though you can only watch on two devices simultaneously.
When watching on a device (and not casting) you can watch in an 'enhanced' mode which gives optional camera angles and the ability to jump back to highlighted events such as goals/tries etc.
When I got it there was a half price offer for the first 6 months. It may be worth asking Plusnet for a similar offer.
russspur
Thanks FttpPeter.
I was aware that offers had been made but apparently not if you had the BT Sport on TV  so I will ring and ask. Just one final question is your broadband extremely fast- mine is fibre but maxes out at about 21 but good enough for Sky Go App.
Russ
FttpPeter
My WiFi and homeplug/Ethernet speeds are over 21 Mbps but I’d have thought the BT Sport app would work fine at 2 or 5 Mbps.
russspur
Thank you I'll give it a try
Russ
