BT Sport App
BT Sport App
Due to the sad demise of my old HDD I have had to reinstall everything.  Problem is that BT Sport accepts my BT ID but says the app is not activated.  It had been working OK for at least a year.  Do I have to cancel the app and reinstall,or is there a simpler way?
4 REPLIES 4
Fixes: 963
Re: BT Sport App
Hi @juliaandy I'm sorry to see you're experiencing problems with your BT Sport App. For some reason it looks like the App is showing in an 'unconfigured' state instead of 'Active' on your account so I think it's best if we remove it and re-add.
If you'd like me to go ahead with this, could you reply to this ticket with confirmation you're happy to?
Re: BT Sport App
Please go ahead with the fix, I'll just be happy to get the app back!  Cheers
Fixes: 1,130
Re: BT Sport App
Moderators Note
This topic has been moved from Tech Help to TV
Fixes: 963
Re: BT Sport App
Thanks for getting back to me @juliaandy
Cool, I'll be happy to although could I just ask you'd reply to the ticket first?
Keeps things documented on your account. Cheers
