BT Sport App
Victormildrew
BT Sport App
Hi newbie here.
Not been connected yet.  Reading a thread on not being able to connect to the BT sport app with Plusnet and having a problem creating BT ID because of having the same email address when they were with BT.
I will be taking the sport's app, I used to be a BT customer and have used the same email address with BT and now with Plusnet, do you think I would have the same problem when trying to create a BT ID or would it be advisable to change my email address in my account before ordering the sport app?.
Many thanks.
2 REPLIES 2
Fixes: 1,138
Re: BT Sport App
Hi there and welcome aboard.
In these instances we should be able to arrange BT to manually create the ID for you, however if you can it’s probably much easier and quicker to change the email address in your account before you take out the BT Sport app. When you’re setting up a new BT ID I’d then recommend using this email address.
Hope this helps and let us know how it goes.
Fixes: 1,285
Re: BT Sport App
Moderators Note
This topic has been moved from General Chat to TV
