BT Sport App - Issue with BT ID - Although possibly my fault
DeadlyD
I tried to set up my BT ID to use the BT Sport App and the email I use for Plusnet is the same as the BT ID I use for managing my mum's BT account. I didn't think this would be a problem but clearly it is as I'm not able to login. All I want to do is be able to start over again and create a new BT ID but can see a way of doing this.
2 REPLIES 2
djcjuk
Re: BT Sport App - Issue with BT ID - Although possibly my fault
Try the info on the link below to see if that helps.
https://www.plus.net/help/tv/bt-sport/bt-sport-app/
DeadlyD
Thanks, I can't see anything that works on here. My BT Sport App package has been added to my mum's BT account rather than mine as I can see when I log into her account. due to me using the same email for Plusnet and her BT account!!
