BT Broadband Extender Flex 600 kit
OldFrank
It is impossible to watch live football with these devices as they do not reach the speed needed, i have run speed tests on them and the average speed was about 6Mbps.
3 REPLIES 3
Fixes: 214
Re: BT Broadband Extender Flex 600 kit
@OldFrank
There are two issues here: First have you checked how fast your Ethernet connection is when using a computer connected to your router via an Ethernet cable to conduct a speed test? This is the fastest possible speed that your Powerline extender can transfer data..
Secondly, Powerline device performance is dependent on your house wiring arrangement. This might give you a bit more insight:   https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Powerline-Unit-Performance/m-p/1607450...
Mads
Fixes: 79
Hello @OldFrank,
Thanks for reaching out.
Sorry you're having trouble with these powerline adapters, as @Baldrick1 mentioned can you supply a wired speed test - do you have the powerline adapters for a specific reason i.e. TV services?
Thanks .
 Maddy S
OldFrank
Hi.
Thanks for the replies.
Speed test direct from router to laptop 34.5 Mbps, which is good.
powerline adapters next to each other in the same double wall socket one connected direct to router with the 10 meter cable supplied with you view box, short cable from second adapter to laptop 12.9 Mbps, which is bad.
I have cancelled my TV subscription and will be returning all the equipment.
As far as I am concerned this matter is now closed.
