BBC iplayer HQ / HD ?
mikeonforum
I used iplayer on my youview+ box for the first time the other day. I noticed there was no 'HQ' type button on the player. The image looked decidedly standard definition to me. Does anyone know if iplayer always streams one quality setting / if there is no HQ support / if I am missing a setting?
thanks,
Michael
5 REPLIES 5
MatthewWheeler
Fixes: 405
Re: BBC iplayer HQ / HD ?
You'll need to go into the settings in BBC iPlayer and change video quality to Best Quality.
 Matthew Wheeler
mikeonforum
OK Matthew, I'll have another dig around. I usually spot these things but maybe not this time. Thanks again.
mikeonforum
Sorted, thanks for your help.
MatthewWheeler
Fixes: 405
Glad to hear that's done the trick.
 Matthew Wheeler
gbear45
I hope you have notice that if you do set it to " best quality", the picture is now very much better, similar to HD broadcast quality. Its most noticeable on studio based shows.  Though it does depend on the speed of your internet connection.
Its also the same on the bbc  sports APP, some events have a near broadcast quality, but others still suffer from low frame rate.
But generally much better Smiley
