BBC Signal via youview box
Mayfly
Seasoned Pro
Does anyone else have to wait ages for BBC TV signal when routed via the youview box?
All other channels are fine but BBC especially BBC1 takes up to 2 minutes - with the message 'poor signal' on the screen - then about 2 minutes later BBC programmes pop up with no other problems.
Happens every time the box is switched on but only to BBC Channels.
2 REPLIES 2
PeterLoftus
Re: BBC Signal via youview box
Just a thought. Did you select a region when you set up your box. Perhaps you selected a region which isn't your strongest signal  Huh
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Mayfly
Seasoned Pro
Yep all the local news stations are the correct ones. It's strange why it takes so long for the signal to come through almost as tho' it's back to valve days when it needs to warm up.
