Amazon Prime App
JohnW8992
Amazon Prime App
Hi, the Amazon Prime app is not showing any videos when I press play.
The app shows all the programmes, but will not play any. It just says error.
Is there a current problem that anyone knows about, or does this not work with Plusnet TV,
Thanks for any help.
1 REPLY 1
PowerLee
Re: Amazon Prime App
The Prime video app works fine on my Plusnet YouView box.
Press the blue home button on your remote, scroll to SETTINGS then SOFTWARE INFORMATION & check for box software updates then check for app / player updates.
Maybe checking / updating the box will help.
