All IPTV Subscription Channels Missing
Fixes: 613
Re: All IPTV Subscription Channels Missing
@DaveCW wrote:
Not sure if this is relevant to the issue... i have the Youview app on my mobile and none of the Subscription channels show there either.
From my experience the app picks up the channel list from the box - the IPTV channels didn't show on the app for me until they were activated on the YouView box.
So if the box has lost the channels they will disappear from the app.
Fixes: 240
Hi @DaveCW and @Larry63, could you both try rebooting your routers and factory resetting your set top boxes please. I've discussed this with a colleague and made some changes on your account to try and narrow down where the problem may lay.
If you could let me know how you get on after this and if the channels re-appear, that'd be great.
Thanks.
 Harry Beesley
 Plusnet Infrastructure Operations Professional
DaveCW
Done as requested factory reset router then Set top box. All now appears to be back. The difference I noticed this time was a software update in the box reset process.
Whatever you chaps did seems to have worked.
Many Thanks
Fixes: 240
That's great news, thanks for letting me know!
 Harry Beesley
Larry63
Yep. All working fine now. Cheers
Fixes: 716
Glad to hear that! Thumbs Up
I'll let Harry know. Sorry for the time it took to fix that for you.
Let us know if you need any further assistance at all.
