Advice for new router
Dazzellbrush
Hi everyone,
I have just ordered Pn tv and I currently use a dual band Western Digital router N750, I love the router but I am not sure if it does multicast, after checking online nothing really comes up about it I guess they didn't sell very well.
After spending a few hours looking online it seems hard to find routers that will definitely work and preferably have plug and play capabilities with You view from Pn.
I need a decent spec dual band router with the ability to port forward for gaming and cctv access.
Can anyone recommend a good router for me?
Many thanks
Daryl
4 REPLIES 4
Den1
Re: Advice for new router
I use this one  http://www.amazon.co.uk/gp/product/B00NEQZ12Y?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00
Works out of the box just need to enter your plusnet login details
Dazzellbrush
Thanks for the reply, looks a good router that one.
Dazzellbrush
Just ordered the router thanks again for your help.
Den1
Excellent  Wink
